Did you prime the pump, Jack?? Take the banjo bolt from the block where the line to the filter attaches. Pour or squirt oil in there until you think it should be full. Reconnect everything and give it another shot.
Jeff
Oil pressure I have, need to adjust timeing and carbs now but it is late, tomorrow. Will not go above about 1500 and does not want to idle, and you know I marked the dizzy before I pulled it. So much for that.
Once I get it timed and running up to temp will let you all know how it went.
