startech47
I used to use dye check for cracks. You applied red dye to the parts and than wiped it off. Than you sprayed on a white power coating, looked like you painted the part with white paint and it sucked the red dye out of the cracks leaving red lines that were easy to spot. In your case it should be yellow or black on white.
