Today was a good day for Tunebug progress. The evening started with some frustration around removing the steering column -- which needed to be pulled to get the exhaust header in place and was resolutely refusing to budge. A quick trip here for advice and I had the instructions necessary to get the job done.
Once that was out of the way I grabbed the world's most useful tool (the Dremel rotary tool) and did a minor bit of grinding to make room for the header. A nip here and a tuck there and the header was in. On went the carbs and the air/fuel side of the engine was looking good!
A few days ago I installed some of the bits on the other side of the engine as well, so the oil filter housing is in place (thanks to fellow BCFer John Kuzman for the proper gasket) and the distributor is loosely in place as well. The distributor will still need to be placed properly, as it's probably 180 degrees out -- I didn't check the location, just got it in place.
Still a lot of fiddly work to do, but this was a nice bit of progress. Lots of adjustments and setup to do, but I should be ready to fire up the engine in a few weeks. Feels great to be getting closer!
Hi Guest!
