Progress as of today
Moseso
I have been an avid reader here, asked some questions and, when I felt I had a good answer, answered a few. But I have been very stingy with the pictures. This is primarily because I am loath to stop what I'm doing, wash my hands to the point where I am willing to touch my camera, and use it. There aren't many pictures to post.
Last evening, I married the engine and tranny and secured them to the frame. The front end is done as far as it can be without some more weight on the frame to allow external compression of the springs to allow installation of the shocks and lower bump-stops.
The motor was done at my guitar repair shop over the winter -- the garage is unheated. The existing 87mm pistons and jugs were deemed reusable. New rings, bearings (main, big-end, small-end and cam) were installed along with an Iskenderian "TR 23" cam: duration 260, lift .440" (new lifters, of course!). The head was surfaced and fitted with hardened seats, valves and new cast-iron guides. The distributer was overhauled by Jeff at Advanced. My one nod to engine jewelry is the pretty Offenhauser valve cover.
The body is painted rat-rod style in powder bluish flat epoxy primer on the outside. The frame, underside of the tub and the engine bay are all finished. Should my ship come in and I decide to finish the top side, it won't be necessary to part the frame from the body again to do a proper job. The engine bay is white so I can SEE what is going on in there. An odd choice, I know, but I think it will be a help as I continue to age and my eyesight does too.
Things are moving along well enough that I think it VERY likely that I will get some road time in before the snow flies again this year.
Nice job!!! It's beginning to look like a real car again.
Looking good. You have done well and it shows. I have been as actively reading as you, and have been taking tons of pictures of mine along the way. I think I may have sent you a few but I know I'll need them when I start putting things back together. What an incredible project. It's over 100 degrees in my garage now and a little warm to be working on the TR3.
I like your colors.
Give me 100 degrees in the garage anyday!! It's less than ideal, I know, but you <span style="font-style: italic">could</span> work in 100 degrees. You can<span style="font-style: italic">not</span> work in the garage when it's 10 degrees -- or worse -- 25 below.
I haven't taken the, no doubt, good advice to take lots of pictures as an aid in reassembly -- reasons cited above: I'm working too intently to stop, degrease and pick up the camera. Careful layout of sub-assemblies and marking of bags of parts is working well, aided by the official shop manual and parts books. AND -- pictures I've copped off the BCF! Thanks, all, for the help!
