tr3 with a tr4 trans with od. the od pops in, but doesn't let go. even if i power off the car, the solenoid does not release. if i remove and replace the solenoid, it again pops in but not out. i have another tr4, where the od works fine. i notice on this car that there is some sort of downward pressure on the od lever. there is none on the tr3. if i swap the solenoid units, it makes no difference in either car. the tr3 is getting power obviously to the solenoid; tested that.
am i correct in assuming that there is some sort of spring mechanism in the od that causes it to release, and that has failed in the tr3? and that i have to pull the tran, pull the od, and fix that? i'm assuming i can't remove the od from the tran while its still in the car?
Hi Guest!
