I know that it can be confusing.RJS said:OK, I realize the question was about Pertronix, not the coil. But.....
About 3,000 miles ago I did install the Pertronix Ignitor because my dizzy shaft had a slight wobbling (coulda just had it rebuilt I guess). Since then, the Pertronix performs flawlessly.
But, about that coil. I went with a Pertronix Flamethrower coil to match. It was offered in both 1.5 ohms and 3.0 ohms. With no other info or input, I ordered the 1.5 ohm model. But, I have always wondered to this day if that was the right choice.
As I said, the package has performed flawlessly for me.
Geo Hahn said:Ahhhh... Pertronix v Points, DOT5 v DOT4, Toe-may-toe v Toe-mah-toe, Boxers v Briefs.
Have to remember it is winter in some parts of the world.
Bob, You can also open up your plug gap when using the flamethrower, I have the ignitor and flamethrower in the B with the gap set at.035 and the increase in power is extremely noticeable.RJS said:OK, I realize the question was about Pertronix, not the coil. But.....
