Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs?
dcoplan
I'd like to put K&N filters on my Bugeye but the smallest size Moss carries are 1-1/4". Any idea if these can be adapted to my smaller carbs?
Gundy
These are very nice. Functional and pretty too. If you want to show stacks the K&Ns are a snap to remove.
They do WORK. I can hear those HS2s sucking over a loud exhaust. Love that sound.
dcoplan
dcoplan
I checked the links but they don't address my issue which is trying to find out if there's a way to adapt K&N filters for 1-1/4 SU's to my 1-1/8 SU's. K&N makes them for the larger size, not the smaller size. Wondering if some sort of adapter exists and if it would even make sense to do this.
dklawson
What I was trying to suggest was that if you wanted to use K&N cones, contact Hap and ask him if he could make a set of adapters for your smaller carbs.
dcoplan
dcoplan
Doug - gotcha. Didn't catch on to that the first time. David - yeah that might be something I look into in the future but for now I've got my hands full with a total engine rebuild and the incredible frustration of getting parts from Moss that don't meet spec and end up being totally useless. Along that line, any of you have a reliable source for parts? Moss really is a crap shoot - half the stuff totally fine, the other half worthless.
apbos
So I am running a 948 with 1 1/8 carbs. The 1 1/4 filter bolt holes are very close in spacing, but they have 2 small breather holes (vs one for the 1 1/8). So you would have to fill in one hole and open up the remaining breather (see picture I placed them over a 1 1/8 carb). I have a set of pan air filters for the 1 1/4 carbs that I pan to do just that when I run the car on the road and use the stock Coopers for show. They use a John Deere 110 air filter that you can get from NAPA. As an alternative I guess you can just make your own filter plates and use what ever filter you want. AH spares in the UK has lots of good parts. If you have problems with your Moss parts send them back, they will make sure they work or refund you.
Paul
dklawson
Apbos, John Deere filters? Can you give a bit more information on them... like their dimensions?
apbos
Doug
They are Napa part number 2374. My local Napa dealer fit them for me and told me they were for a John Deere 110 tractor.
Air Filter Height (Inches) : 2.34"
Air Filter Style : Air Filter
Bottom I.D. (Inches) : 3.002"
Bottom O.D. (Inches) : 4.393"
Top I.D. (Inches) : 3.002"
Top O.D. (Inches) : 4.393"
Air Filter Height (mm) : 59 mm
Bottom I.D. (mm) : 76 mm
Bottom O.D. (mm) : 112 mm
Top I.D. (mm) : 76 mm
Top O.D. (mm) : 112 mm
Paul
dklawson
Thank you. I'm going to print that out and save it for future reference ! Much appreciated.
I've used those short filters on some of my cars. They were used on a bunch on small engines. They seem to flow enough air. I did not notice a need to change mixture settings.
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 7
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
DarwinT Weber carb and possible vacuum hose Spridgets 10
