SkinnedKnuckles
First off, I would like to acknowledge the wisdom of Randall & Poolboy and the "encouragement" that got me off my duff to find the ported vacuum tap on one of my carbs. I remember now it was there, but when I went to the triple set-up the vacuum retard was still in play, and besides I hadn't heard of ported vacuum anyway.
So this morning I rediscovered the tap and hooked it up. My impressions after a warm-up and idle adjustment:
• There is more power available when starting off in 1st gear which will help prevent stumbling. Makes sense because now the timing is increased on take-off rather than decreased. That's also why according to a single reference ported vacuum was adopted in the 1930's.
• Warm starts seem easier. Don't know about cold starts - only had 1.
• RPM's drop like a rock when shifting if you totally let up on the accelerator. Maybe I shift too slow when cruising. Not a biggie, just takes some getting used to.
• Idle stability - no apparent change.
• Cruising performance - no change.
• HC emissions - decreased :wink:
So there you have it. I was pleased with running vacuum advance off the manifold (retard) port for years, but am more pleased now. Thanks, guys.
