POR-15 question
mgbmedic
Anyone who's ever used POR-15 on metal with rust holes about the size of a dime? Can I use a fiberglass patch on the rust holes and then cover with por-15? Will the two interact together? Workin on a "driver" the PO left under a tarp for ten years in Ohio Valley humidity. PO used a sponge-like carpet backing and the floor boards rusted from the inside. Outside, they're rust free. Whenever I've stored a car for long periods, I always bought several cans of furniture polish, sprayed the ubderside of the car, removed the carpet and sprayed the floor boards. Really worked well to prevent rust and had a lemon-y smell.
That is what the POR-15 trunk kit consists of. I've been told it results in a hard durable finish. Probably want to make sure that there are not seat belt fitting or similar right next to the patch.
/ubbthreads/images/graemlins/nonono.gif
Ed /ubbthreads/images/graemlins/cheers.gif
POR will be fine with fiberglass. POR also sells their own brand of fiberglass mat, it's point-bonded, not woven. It's a good choice for low profile patches and it won't have the tell-tale woven appearance of common fiberglass.
POR's patch compound (at least what I tried) is an epoxy putty. It is rock-hard when cured. It's also a good choice for patching holes but it won't be low-profile when done.
Ahh shucks, this is trunk right? Wire brush to bare metal, fiberglass, and paint with rustolum and cover with trunk carpet. It will last for ever.
Now, Jack, would you do that to the "Cave"?
Yea, just might. In fact have done that before.
Well, I have NO clue why the words I wrote this AM did not show up so here is what I said Again?!?!?
I suggest you hop on over to Spridgets List and ask Frank C. ( Spritenut ) how he feels about POR-15 and what it did to him.
Ed
/ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/cheers.gif /ubbthreads/images/graemlins/confused.gif
