Piston fit
wdp
Started to rebuild a motor for my BGT, and the block turned out to be bad. I was going to use a block from a 67, but have switched to an 18V, my question is can I use the circlip pistons on press fit rods? I am rebushing the rods.
Hap can explain that one...but, yes, you can have the pressed rods modified to take circlip pistons...have to drill the bore to take the bushing & drill an oil hole.
Where's Hap when you need him?
