JPSmit said:Gliderman8 said:When I replaced my pinion seal and had to re-torque the nut, I used chain and a bolt..... I wrapped the chain around the axle and inserted a bolt through the chain, and one of the holes on the flange. This kept the flange from turning as I tightened the nut. Let me know if you need a better description.
I need a better description.
This should help....
<span style="font-style: italic">edit: I wrapped chain over the front housing of the diff... not the axle</span>
