regularman
Again worked all day on the "new" midget. I finally ran out of welding wire and quit for the day. I got the new sill installed but could not finish welding all the tiny holes I drilled. I ended up taking more time and building a new lower hinge support out of some metal I had and welding it in place.
The pictures are mostly of the surface rust in the places I found it and the few rust through places. I went out and bought welding wire, so the plan now is to finish the welds and weld a small plate in the front of the panel I installed and then another small scab plate in the driver floorboard where I found a hole.
I plan to then coat everything with por-15 and then top coat it.
I plan to paint the car purple so the engine bay will probably be a light purple color.
Toward the end is a pic of the missing cover or cap on the transmission seen the shifter hole.
