richberman
Does anyone have pictures of how the front disk brake conversion plates mount? I'm using the AHSpares kit.
thanks in advance.
rich
thanks in advance.
rich
Hi Guest!
For both the rotors/hubs & mounting brackets: insert the bolts from the outside of the car towards the inside (the nuts are on the inside; or perhaps they're the one inserting the bolts... :wink: ).AH100M said:Correct.
Oh, in the email thread between me and AH Spares - I asked a question about which way a bolt goes in - head in or head out? He said it makes no difference. Turns out it does. I don't remember the particulars but I think it's obvious when you actually do it.
Randy Forbes said:For both the rotors/hubs & mounting brackets: insert the bolts from the outside of the car towards the inside (the nuts are on the inside; or perhaps they're the one inserting the bolts... :wink: ).AH100M said:Correct.
It looks to me like the bolt orientation is model specific. BJ8s have the bolt head on the inside (mine is like Randy's photo) and earlier cars have the head in the hub. If you look at the Moss brake pages for the different models, you'll see the bolt is different. Both in orientation and part number.richberman said:Randy,
Why are your nuts on the outside here?
Jerry said:I did not have to do any grinding for my BN4, but I did put about 4 washers in to center the caliper on the rotor. The brakes work great. An amazing difference to drum brakes.
Jerry
BN4
BJ8
I think your correct about the self-centering. One thing to check is the rotor to be sure it is not warped or wobbling(correct bearing adjustment).richberman said:Ok,
I've got the calipers on the rotors now, but as you can see below, the rotor touches on one pad, which stops the rotor from turning. Do I need washers to center the calipers or are they self centering once everything is set up?
