19_again
My positive ground 67 B got a new Flamethrower last week, and at that time I just disconnected the existing terminal connections and reconnected to the new coil. Tonight I tried to install my new ignitor to complement the new coil. Before the ignitor, I had a wire running from coil negative terminal to the side of the distributor and the positive terminal was connected back to the powerblock. This setup worked fine for quite a while. Now when following the directions in the ignitor, I have a black/white wire going from the coil negative terminal into the distributor, and the wire that was hooked up to the positive terminal on the coil is now connected to the other (black) wire coming from the ignitor. Another change is that now I have a ground wire attached to the positive terminal on the coil and the engine turns over fine, but won't start.
What am I missing?
Answered by the great support team at pertronix. I had neglected to re-install the rotor cap. Everybody at ease, go back to your homes, there's nothing for you here.
What am I missing?
