BJ7archaeologist
Fellow Healeyoids, I recently installed a Pertronix Flamethrower distributor. My Healey has been converted to neg. ground, the dist. is a neg ground unit. New plug wires (non-solid core). I hooked up the two wires from the dist, red to pos, black to neg. A small plume of smoke arose when the ignition was turned on. No start. Pulled a plug, grounded it, no spark. The dist. unit is toast. Have others had a problem with Pertronix? I stuck my dist. back in with points and the engine fired right up. Oh, and I installed a new Pertronix coil to replace the old Pertronix coil too! No start, no spark with the Pertronix dist. I'm junking the Pertronix unit. This is the second one on a Healey that has failed to work. What other electronic ignitions are worth using?
Randy
63 BJ7
60-BT7
Randy
63 BJ7
60-BT7
Hi Guest!
