kennypinkerton
Re: Petronix - Pros & Cons
I'd say a good head removel and carbon cleaning are in order... And I think the carbon buildup in that cylinder may be causeing the intermittent and low compression readings - could be carbon buildup holding a valve open sometimes, and allowing leakage. Then, you need to find and fix the cause of the excess carbon. Carb rebuild maybe?
