Johnny
I purchased, at one of the AHCA annual Conclaves, can't remember which one, a set of pedal extensions just made for that purpose. There nothing but a length of 1/4" aluminum 4" x 1 1/4" inch with 2 holes drilled in each end. One set of holes are offset to match those drilled in the clutch pedal. To mount you merely have to remove the pedal from the car, On 100/6/3000 models reuse the spacers and mount the extensions on the right side of the pedal. On 100/4 models add spacers and use the longer 1/4" bolts (provided). I recall the kit was only about $9. Works great. Perhaps whoever made these up still has some available.
