Pedal box blanking plate
Rut
Good morning! As I continue to assemble my Bugeye I run across parts that were 'restored' early on and they are not up to the level that I want. One part is the pedal box blanking plate. Mine is a little rough around the edges and a PO drilled a hole in it. Does anyone have a plate that's in good shape they would part with or know of a source?
Thanks, Rut
If no luck here, AH Spares 7 pounds 95 plus shipping for XBRK117 for a 'Blanking Plate - Pedal Box'. Doug
Rut I sourced one of these via MOSS some time ago. In my box of parts to reassemble but if you need one in a hurry.
Jim,
Thanks, Moss no longer lists the blanking plates, but they do have the gasket. I'll keep looking and if I discover I need something else from the UK I'll order one then.
Thanks, Rut
I have one that is in decent shape but has two 1/8" holes about 4 1/8" apart. It would not be a challenge to plug those holes.
Nelson,
Thanks, that sounds like the one I have! I may end up welding them up and grinding the weld and the pitted areas down.
Thanks, Rut
Ray,
Thanks, please let me know.
Come to think about it the one I have came from Ashley.
Thanks!
Rut
