It looks like you have done away with them entirely in your profile pic. Probably safer to shoulder check anyway than to relay on the wing mirror.Honestly, the wing mounted mirrors are a losing proposition. Every wing I have owned (8 wings over 2 restorations) have had at least 3 holes where the mirrors were installed, broken out, relocated, broken out, etc. There is too much vibration for 18gage steel to support. Now, if you could mount a steel backing plate to distribute the load, I think it would be more stable and hold an alignment better...but that is something you would have to do during a paint job.
Is that a self tapping screw holding the mirror bracket to the stanchion? I'm wondering if that setup would work on the passenger side because of the angle of site? I think I saw where someone had mounted a Harley Davidson mirror to the stanchion....have you ever seen that?I could not keep mine adjusted and if I could do it over I would have welded the holes up.
Made a mirror mount that goes n the windscreen stanchion. It works well and I can adjust it as I drive if I have to. It is also a convex mirror which helps a great deal. The mirror on the wing is flat so it has a very small field of view.View attachment 68174
David
It is a Chrome Button head socket cap screw that matches the Stanchion mounting nut. I bought a pack of 10 from Mc Master Carr. Works great. Bent up the SS bracket from some material I had in the shop.Is that a self tapping screw holding the mirror bracket to the stanchion? I'm wondering if that setup would work on the passenger side because of the angle of site? I think I saw where someone had mounted a Harley Davidson mirror to the stanchion....have you ever seen that?
That looks like a great way to solve the problem. It dosn't look like the wind wings would fit after that mod though? Guess a person just goes for one or the other.
