TR2/3/3A Part Identification
  • Thread starter Thread starter tdel
  • Start date Start date
T
tdel
Hi All, I am back now, engine rebuild is finished and the mechanic is putting the car back together. Now after several months we have forgot where the parts in the photo go....I am sure folks here can identify. We think the semi-circular parts go on fan assembly. I cannot identify the bracket....
the first is for the fan shaft at the front of the crankshaft. The second one I have seen it, but can't remember where it goes.... Maybe the front suspension?
2nd part is one of the two brackets that hold your block rubber motor mount in place. Four are needed for engine install.
Pat
The top piece in the left photo does look like the weight used to balance the original fan, P/N 107858. But I don't recognize the bottom one. Looks kind of like a weight that someone has cut down?
As Pat said, the right photo is the "steady bracket" that goes on either side of the front motor mounts, PN 106428. But most cars (including mine) seem to be missing those pieces, as they make it a lot harder to install the mounts.
Yes, well, there was only one bracket on my car (supposed to be 4 as Pat mentioned). I guess that is why we could not figure out what it was. Memory fades after a few months! Good news is that the car should be running by week's end
I ended up buying a couple of those motor mount brackets from Moss. My car had two originals and two that were homemade by some PO. I'm sure my mounts will be much stiffer than yours, Marv! Hah.
Pat
