There used to be a process called "pinning" that involved drilling a hole at each end of the crack, tapping said holes and screwing a small bolt into the hole and cutting the top off flush. Next a second hole was drilled next to the first hole and slightly overlapping it. This was tapped and another small bolt screwed in and cut off flush. This was repeated untill the entire crack was filled. Done properly it was water tight in cast iron. Old tech and not used much anymore but it did work. Paul.
