Panhard Rod
John Turney
I've discovered that the bracket welded to the rear axle to attach my Panhard rod has broken loose from the axle. To keep the rod from rattling about, I've removed it for now. It looks like I will have to remove the rear axle to re-weld the old bracket or a new bracket to the axle.
Has anyone else had this happen? Should I totally disassemble the rear axle for rewelding, or can I leave the axle shafts and pumpkin in place?
I'd weld it up in place. Can you get light and access through the rear seat pans ?
I had that happen. On my two-seater it was impossible to re-weld it in place. I had a professional stick welder give it a try. You'd probably need to undo the axle from the springs/driveshaft/brake hose and slide it out of the wheel well.
I blamed the "uprated" Cape mounting - was yours stock? Since I have a tube shock mount, I modified that instead of re-welding the stock mount.
PS - after running the car for a while with the bar disconnected (unbeknownst to me), I definitely believe the handling is better with the bar.
Haasad: Even though I have a "4-seater", I doubt there is enough access to weld it in place. I can't visibly see the welds well enough.
Steve: I have the stock rod, but I replaced the rubber bushings with poly bushings. I have the stock rear shocks. I'm trying to figure out your modified tube shock mount. Is the big hole on the left where the Panhard rod attaches, and the bolt at the bottom of the photo where the shock attaches?
I don't want to hijack this thread but can someone post a pic of how the panhard rod attaches to the axle on a 100? I have the bracket on the frame but have a ford 8 inch rear and would like to fab a bracket to install one. Thanks!
Naw I just took my car to my muffler shop N they welded it on the rack in place-:applause:
Questions: right on both counts.
I started with Cape rear tube shocks, the lower mounts of which were poorly designed and broke after a while. I developed stronger replacements.
Keoke - did you have an older Healey prior to your two BJ8s? The cars you have now don't have the panhard bar.
John - My welder was not able to get his head with helmet into the wheel arch to where he could see to weld the bracket back inside the axle spring box. I didn't pursue it further because of my idea to modify the shock mount.
This might work if you can weld at your site.
Undo driveshaft, u-bolts, brake hose and possibly e-brake cable. Undo rear of left side spring; allow to hang down to floor. Rotate axle pumpkin upward so rear of axle spring box is pointed downward. Now you have access for welding.
If this doesn't work, continue and slide the axle out to the left as needed.
I've been blaming the Cape setup for putting extra stress on the stock mount, but it looks like a weak design to have given out after lo these many years. :smile:
No N don"t tell em that.:wink-new:
OH!! U mean that big one.--Yeah U Right-:highly_amused:
I figure the four contributors to failure are:
  1. Almost 60 years of age.
  2. The poly bushings are a bit more rigid than the rubber ones.
  3. 185 and 195 width radial tires allow more side load.
  4. Spirited driving.
Good reasons to reinforce it when you weld it. Or even come up with a beefier design.
I don't really have welding capability in my garage for something like this, so I'll be pulling the axle out and taking it to someone who is a much better welder than I am.
