I've discovered that the bracket welded to the rear axle to attach my Panhard rod has broken loose from the axle. To keep the rod from rattling about, I've removed it for now. It looks like I will have to remove the rear axle to re-weld the old bracket or a new bracket to the axle.
Has anyone else had this happen? Should I totally disassemble the rear axle for rewelding, or can I leave the axle shafts and pumpkin in place?
Hi Guest!
