Paint.......colors
Tr3aguy
I know this is a simple question.....but I just need to know what is the proper color for the air filter on the TR3....Mine are beat and will get blasted tomorrow....Got a table top blaster running...
Is is best to clear coat after painting?
Thanks
MGTF1250Dave
Aloha JP,
From the TRA judging guide, "Air Cleaners. H4 and H6 systems use different filters due to the differences in air openings. The two types are not
interchangeable although identical in outer appearance. Filters are painted black. "AC" decals are placed in the center of filters. Decals are round or rectangular (believed changed from round to square in 1957), dark blue, and
have white lettering. Paper element replacement filters which might provide better dust filtering are not acceptable
for concours showing."
MGTF1250Dave
JP,
Mine I would describe as a satin black finish, but that my be due mostly to age of the paint. I've seen others that have a more glossy black finish, but not a high shine, mirror finish. Here is a photo I found:
DougF
If you aren't worried about show, I would paint them black, put the label on them and put them on the shelf or hang them front and center on a wall. Then install a set of K&N's.
The original filters are gravel strainers and aren't as effective as new filters, and with the cost of engine builds are nice insurance to longer engine life.
rlwhitetr3b
Bronze
I agree with Doug. My TR is not currently running, but twenty years ago when it was I had some cheap paper filters on it. If I was worried about show, I'd drive it to the show and then switch to the orignial style.
Geo Hahn
I use some foam koozies on my stock filters to improve filtration a bit:
Better than the stock filter alone, no idea how they would compare to the K&N. Neither (koozie or K&N) are going to be as effective at filtration as a paper filter.
Don Elliott
Mine are the original filters that came new on my 1958 TR3A. I had them sprayed glossy black in 1989 and here they are 20 years later. I never lost a point at any VTR or TRA concours event.
Like George, I bought a foam filter at Sears for my wet/dry vacuum for my garage and cut it to give me 4 pieces as shown to improve the filtering effect. I oil them with Amsoil Foam Filter Oil. Only takes a second to pull them off at a concours event.
Vaark01
JP,
Mine are semi gloss black with labels. I have them on the shelf and run with K&N filters.
Paul
Vaark01
JP,
It's still in the shop, but should have paint on it by now. After much thought and discussion on the Forum, I decided to go with Old English White. My hope is to have it back in a couple of weeks. A new set of Panasports and Vredesteins awaits its arrival.
Are you going to Collingwood this morning?
Paul
Tr3aguy
Tr3aguy
OK...not my best paint job and I had a dent that I tried to massage out....not my strong point but I think it is a step forward....thanks again for the help....small victories will win the big battle...one step closer...
Before..Note the dent in the rear filter
After.. I could have bought new but what is the fun in that!!!
Darrell_Walker
Looks good! What happened to the pine cone? :smile:
Darrell_Walker
Tr3aguy said:
What is the best thing for polishing the pots on the carburetor?
Depends what your goal is. If you just want to brighten them up a bit, some metal polish (I've used "Blue Magic") and a rag will do wonders. If you want a mirror-polished finish, you might have to start with wet sanding (depending if there are any nicks/scratches), and use a buffer with various compounds.
60TR3A Who Supplies Original Paint Colors? Austin Healey 12
TR3Dad TR2/3/3A TR3 Paint Colors in a Can? Triumph 16
L Sources for Original Paint Colors Spridgets 9
R TR2/3/3A TR 3A Original paint colors for parts Triumph 2
vping MG Paint Colors MG 4
O TR2/3/3A TR3 Paint Colors Triumph 25
T So let's talk paint colors... Triumph 39
V Rostyles: what paint colors??/ Spridgets 3
bighealeysource BJ8 paint colors Austin Healey 7
P TR2/3/3A 1958 TR3A Paint Colors & codes? Triumph 6
PAUL161 MG Paint Colors 1938 to 1980 MG 0
71TR6 TR6 TR6 Paint & Trim colors Triumph 6
B Suspension Parts Colors and Paint Recommendation Austin Healey 6
A T-Series Paint codes, chips, colors, etc MG 3
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
