Paging Don - exhaust pic needed please
DNK
Tom, the local parts store might have them. Schucks sells em here.
or
Flex Pipes
He might be out. Don't see the 2x12's
DNK
They come as a butt joint for welding. I took mine to a Midas shop and had them open one end up on both. Took a couple of trips on one of them
The step clamps are from Summit
trfourtune
when you buy flex pipes, it's best to find ones that are as smooth as possible on the inside. You can get sleeved ones if there is not too much movement.
Rob
DNK
Totally agree with Rob. I need the non smooth ones as there is about a 1" offset in the pipes.
tr8todd
Those exhaust clamps look expensive. For years I have been using the stainless steel sleeve clamps for plumbing applications. Throw away the rubber sleeve and just use the stainless. They are called mission clamps and they work great if the pipes slide together far enough. I use them on the all of my cars instead of regular exhaust clamps. Makes getting things apart real easy and they only cost about $5 each.
DNK
Todd- Not to bad
Summit SUM-692200 - Summit Racing® Band Clamps
View Image and Compare
* Summit SUM-692200 - Summit Racing® Band Clamps
* Compare
Exhaust Clamp, Band-Style, Lap Joint, Stainless Steel, 2.00 in. Diameter, Each
Part Number: SUM-692200
Estimated Ship Date: Today
Transaction
* $7.95
K Paging Randall re: Judson Supercharger Vanes Triumph 5
HealeyRick Paging Dr. Entropy Lotus 0
K TR2/3/3A Paging TR3driver re blocked bypass and Shaller pdf Triumph 1
K TR4/4A Paging TR4nut re Timken speedi sleeve? Triumph 4
Tabcon Paging Kai Radicke of Wishbone Classics!!! Triumph 11
7 paging Andrew Mace Triumph 4
K Paging Martx-5...What valve gap are you using? Triumph 0
K Paging Mike P. re BritishIron wrecking yards? Jaguar 3
K Paging Andrew Mace: Re Spifire engines Triumph 1
T Wedge Paging Monica - Is happy TR7 motoring underway? Triumph 5
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
K Paging Doug F ....regarding Petronix Warning Triumph 3
davelgee Paging Miss Agatha Spridgets 16
J Paging Basil! Check it out..The cars a blast! Other Cars 6
Basil Paging Steve - RE: Zaino Restoration & Tools 3
Basil Paging Jagboy! Jaguar 0
T MGB Quick question about something that don't really matter just want to know. MG 9
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
jlaird MGB Don't post like I did 10 years ago. MG 7
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
PC somethin' I don't see evrey day Spotted 1
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
CJD General TR Parts Just Don't Last Anymore Triumph 6
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
Gliderman8 Lights don't break FORUM Navigation Questions 23
S TR2/3/3A Don't throw anything away. Triumph 7
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
JPSmit I don't always dream of owning an RV Other Cars 0
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
Geo Hahn General TR R.I.P. Don Elliott Triumph 13
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
D TR6 Rear lights don't work. Grounding Problem ? Triumph 14
1 MGB I don't know how or why, but I think I will need a new clutch :[ MG 4
Csarneson Old Engine - Journals don't fit? Austin Healey 2
N Things you see when you don't expect it. Spotted 1
HealeyRick You Don't Need a Weatherman ... Austin Healey 9
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
vette Vapor Lock, Out of Gas, Hmm, Ahh, Don't know? Austin Healey 32
Mickey Richaud MGB Don Hayter Gets His Watch MG 1
PC don't know, but I have a pretty good idea, Spotted 0
Lukens Don't hate me... Austin Healey 22
M I don't love her anymore Spridgets 5
D Don't buy top plate shims for bishop cam steering from Moss Restoration & Tools 5
bugedd Don't know what to do Spridgets 17
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
C Order of Assembly? Do and don'ts? Austin Healey 9
