Hi Guest!
Donny_L said:... Should I go ahead and replace those bushings, maybe with some new polyeurothane bushings instead of rubber?
elrey said:Can the solenoid get stuck in the ON position? Last question for awhile. Going back to watching and learning. Thanx, Elrey
The OD may get stuck on, but not the solenoid, at least not likelyJohn Turney said:elrey said:Can the solenoid get stuck in the ON position? Last question for awhile. Going back to watching and learning. Thanx, Elrey
The OD can get stuck in the on position. If I remember correctly my OD clutch was worn and would travel too far. It would not come back when the OD was switched off. I had to gently back up to get it to disengage (until it was fixed).
