Overdrive install problems
Torsten
Hello,
I bought a nice, working overdrive gearbox in the UK (online) for my 1970 USA-spec MGB GT. I asked the seller twice if it is the correct 'black label' LH-overdrive, which is used in these cars until mid-74. Both times he answered yes, but after receiving (and thoroughly cleaning it, long story on the delivery...) I discovered that this is a blue label LH-overdrive, which is used in the rubber bumper cars.
My problem now is that my speedo doesn't match the 1000 tpm of the overdrive gear. The speedo is a 1280 tpm, which is used in combination with the black label OD's.
I now have several options:
1. returning the gearbox: no, because it is in a state way too good for the money I payed for it and it was a real 'struggle' getting it 'all the way' from the UK to the Netherlands...;
2. buy the right speedo: yes, but I'm looking for a matching one (see my pic);
3.calibration of the current speedo: no, way to expensive over here!
4. change the speedo pinion and speedo gear in the OD: yes, I have a set of matching pinion and gear from a broken OD.
At the moment my favourite choice is number 4. But this means I would have to take the OD apart, which kinda creeps me out... Is there a possibility to replace the speedo gear 'from behind' by taking out the rear bearing?
What's your opinion about my little project? Keep in mind that I'm just an enthousiast who works on this case with a friend who luckily has some years of experience working on classic British cars. But this project is a novelty to him too...
Best regards,
Torsten
PSJ
Another option: I had my speedometer re-geared to match my overdrive and the exact tire/wheel size I am running. (Actually, I bought the wrong speedo on Ebay and went this way just to be done with messing around with it!).
Phil
Torsten
Torsten
Well, I found someone who was willing and capable of changing the speedo pinion and gear from my '76 rubber bumper overdrive for a set from a chrome bumper OD. Luckily I didn't decide to swap the speedometer, because when we opened the OD and removed the annulus, I was shocked... One of the planet wheels' bearings was broken, so the wheel carved into the outer ring of the annulus. The result is shown in the pic below. I wouldn't gave gotten far with the OD in this condition... Luckily the good man had a broken OD with a fine looking annulus for me, so we swapped this and the speedo gear and pinion. After some other checking and replacing some gaskets and bearings it seems that the gearbox finally is ready for installation.
Regards,
Torsten
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
