Torsten
Hello,
I bought a nice, working overdrive gearbox in the UK (online) for my 1970 USA-spec MGB GT. I asked the seller twice if it is the correct 'black label' LH-overdrive, which is used in these cars until mid-74. Both times he answered yes, but after receiving (and thoroughly cleaning it, long story on the delivery...) I discovered that this is a blue label LH-overdrive, which is used in the rubber bumper cars.
My problem now is that my speedo doesn't match the 1000 tpm of the overdrive gear. The speedo is a 1280 tpm, which is used in combination with the black label OD's.
I now have several options:
1. returning the gearbox: no, because it is in a state way too good for the money I payed for it and it was a real 'struggle' getting it 'all the way' from the UK to the Netherlands...;
2. buy the right speedo: yes, but I'm looking for a matching one (see my pic);
3.calibration of the current speedo: no, way to expensive over here!
4. change the speedo pinion and speedo gear in the OD: yes, I have a set of matching pinion and gear from a broken OD.
At the moment my favourite choice is number 4. But this means I would have to take the OD apart, which kinda creeps me out... Is there a possibility to replace the speedo gear 'from behind' by taking out the rear bearing?
What's your opinion about my little project? Keep in mind that I'm just an enthousiast who works on this case with a friend who luckily has some years of experience working on classic British cars. But this project is a novelty to him too...
Best regards,
Torsten
Best regards,
Torsten
