Hello All,
When I bought my '59 TR3A in the early 90's it had (and still has) an old style telescopic antenna which could be period correct. It had been hooked up to a more modern Radio Shack type radio which the previous owner had bolted underneath the dash. Now that I am restoring the car, it is time to decide whether or not to patch up the antenna hole while the other body work is going on. OR, to keep the antenna for a possible original radio installation. Would probably only do that if I find sheet metal screw holes in the transmission tunnel where the original radio brackets would have been mounted. If there is no such evidence and the antenna is clearly an add-on, I may not pursue it. But the antenna is mounted just about dead-on in the fender location that is specified in Smith's installation instructions on sites like Terry Ann Wakeman's:
https://www.tr3a.info/radiomobile.htm
Would like to ask a few questions of those who have or had TR2/3/3A/3B's with original factory or dealer installed radios; also those who simply have good information in this regard (don't know if any TR2's had radios except those which were mounted in the glove box area):
- The standard factory radios were apparently Smith's Radiomobile in a number of models and configurations. Is that correct? Did those radios get installed in any cars bound for the North American market, or by US or Canadian dealers?
- Are there any UK, European or worldwide owners that have what they know or believe to be original factory or dealer radio installations? If so, can you provide information and photos of your radio setups? It would be interesting to know, for instance, what the UK home market installations were vs. Germany, France, Australia, New Zealand, and all of those other great and exotic places to which TRs were exported.
- Motorola radios, to my knowledge, were also installed in the US cars. Did they use the same installation kit as the Smith's radios? There is also the British PYE radio mentioned on the Terry Ann site, which apparently used a slightly different mounting kit. Were there other radios routinely installed by dealers?
- Would value any information out there, certainly from those with originally installed radios. Make, model number, push button or not, transistor or valve (tube)....any of this is good info. Most were probably AM (MW) band only, but I think some also had long wave capability. Although there were some transistor radios around for cars in the late 1950's, I believe all or most of the TR2-3A, if not also 3B, were still equipped with tube radios; but would be interested if you have other information.
- Speakers: I believe the standard configuration was one speaker mounted behind a chrome grill above the radio on the tunnel. However, have read that some cars have speaker holes in the foot well sides. If so, were these owner mods only?
There is at least one vendor out there selling a reproduction installation kit:
https://www.britishwi....et-p/tr3rb.htm Do you know of others?
Any photos of your radio installation would also be greatly appreciated.
Regards,
Walter
Regards,
Walter
Hi Guest!
