MGB Oiling foam air filter
Eggsy
Any suggestions on best method of cleaning and oiling the foam air cleaners on my 65 mgb with su carbs.
I hear all sorts of different advice from using gas to clean and engine oil to using specific cleaners and special oil.
how much oil etc. etc.
thanks
NutmegCT
Well, in my case I always used dish detergent and warm water. Soaked the foam, then squeezed out; repeat several times until the squeezed water is no longer dirty. Then rinsed in clear water several times, squeezed, then set in the sun to dry.
Never had a problem - but I guess it also could depend on the manufacturer's instructions.
Tom M.
Grantura_MKI
Do not soak in petrol. These will ignite with one back fire through the carburetor. The reason that they should be bin.
davidb TR6 TR6 oiling trunnions Triumph 7
Gerry M TR6 Trunnion oiling Triumph 7
davidb AH oiling the air filter Austin Healey 13
tahoe healey Oiling the starter Austin Healey 1
JohnnyMead TR2/3/3A Re-Oiling the TR3 Air Filters Triumph 0
C oiling chassis TVR 1
Hap Waldrop Ray's oiling system MG 5
jlaird Oiling your rack Spridgets 6
B TR6 Oiling the carbs in a TR6 Triumph 19
kyreb1862 MG Oiling Kit MG 6
Tinkerman Trunnion Oiling Triumph 6
J Oiling Carb Spridgets 4
jtb55 valve train oiling Austin Healey 2
K TR2/3/3A Foam air filters for S U's Triumph 7
charlie74 Wanted Passenger seat replacement foam [ā€˜74] Triumph Classifieds 0
NutmegCT "Great Stuff" foam sealant Restoration & Tools 5
tahoe healey past post about sholder belt foam Austin Healey 2
G TR4/4A Go to seat springs or foam? Triumph 14
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
CJD TR2/3/3A Foam vs Rubber Seals Triumph 5
T Question on seat foam Spridgets 3
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
J New Radiator Cap - Foam overflow Austin Healey 7
R TR4/4A Best seat foam kits for TR4a? Triumph 3
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
tinman58 General TR Foam in the frame Triumph 11
I Hard top packing -expandable foam Spridgets 5
D BJ8 Front Seats Foam on Back Pan Correct Fitting Austin Healey 4
Got_All_4 Wedge TR7 seat foam Triumph 3
Tinkerman TR2/3/3A TR3A seat back, foam thickness? Triumph 1
Jeepster Foam in rad? Austin Healey 13
W Spitfire spitfire seat foam and skins Triumph 4
S White foam in the radiator?? Triumph 17
B car seat cushion foam replacement Austin Healey 4
R TR4/4A Seat foam tr4a Triumph 4
Jer Sea Foam helped my 74 ! Spridgets 0
bobmga62 Spitfire gwater/foam from valve cover of spitfire Triumph 8
W Seat Foam Triumph 12
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
T Tips for locating/fixing foam rings under gas tank Triumph 4
WALTER Foam for dash rail Spridgets 2
M Seat foam or cushions Spridgets 6
Rhodyspit75 Seat foam Triumph 14
T Any strong feelings on Moss vs VB vs TRF seat foam Triumph 7
D Midget Seat back foam replacement Spridgets 7
B TR6 TR6 seat foam Triumph 7
jollyroger GT6 1970 GT6 seat kits and foam Triumph 9
Steve1970 Can I re-foam the seats? Triumph 22
mjobrien Chassis to Scuttle - Gasket - Filler - Foam? Austin Healey 13
