AUSMHLY
memphis said:Hi All & Happy New Year!
Ended up having to drain the radiator in order to remove the temp sensor without making too much of a mess...
This is the first time I drained the radiator fluid.
Shouldnt there be a copper washer on the drain plug?
Moss shows a drain valve, but I simply have a drain plug without a washer...
Before I refill, is a washer needed? Not sure why is wasnt leaking before?
Thanks,
Bob
There's a saying, it it ain't broke, don't fix it.
I went through 3 drain plugs from Moss. They were the "correct" ones for my car. Every one they sent me leaked. I ended up going to the hardware store and buying a universal plug.
Now I do try and buy parts that look correct in keeping with somewhat of an original car, but if the part I'm trying to use doesn't work, then I give in to what does not look correct, but works.
You've got a plug that works, use it. It's in a area that no one, but you and...well everyone here...lol, will know about. It's not visible.
If the plug is not damaging the radiator bottom and it's not leaking...consider yourself lucky to have one part of the car does not need fixing.
Cheers
