TR3driver
Great Pumpkin - R.I.P
More likely, IMO, wear/corrosion on the thrust washers for the side gears and spider gears, items 11 & 13 in this drawing.AweMan said:My best guess is that the backlash between the ring and pinion is more than O.E.M. specs due to wear on the teeth and or bearings and spacers.
Oddly enough, these are exactly the components that, according to legend, the additive in GL5 (and GL4) gear oil can attack.
