Oil Pressure Line
Bill_Reid
Does anyone know where I can get a new oil pressure line for my 948? The line runs from the combination gauge to the engine block, has fittings on both ends, and appears to have an inside diameter of 1/16 inch. Thanks.....
Jim_Gruber
Bill,
Folks in the past have discussed going to one of the chain parts stores, buying one of their universal oil pressure gauge kits for a small $ amount and using the line contained within the kit and fittings and throwing the rest away. A simple and easy fix. Have not looked into this myself so YMMV.
B
Bill_Reid
Found one on Amazon for approx. $10, supposedly with 1/8 inch copper line. Will let folks know how it works out.
nomad
I'm wondering if anyone has tried to replace the unobtanium guage hose with a section of good used brake hose? Seems as though it should work unless the hose bore is closed up.
Kurt.
LarryK
Copper or plastic line is supplied with the present aftermarket gauges, don't know if I would want the life of my engine relying on rubber hose. The plastic can eventually crack as with copper, but you will notice it hopefully before a real failure. Rubber, even though impervious to brake fluid does not have the continuous pressure the oil line does.
nomad
Personally I trust the original steel line and factory rubber hose far more than the plastic line used on aftermarket guages. A section of brake hose would definelty stand up to the pressure and I may try it the next time I need one. I've had a rubber hose poorly fitted by a DPO let go and it doesn't take long to pump all the engine oil out. Fortunatly I was in the process of parking the car and a fellow noticed the puddle of oil and alerted me to it so no engine damage but what a mess under the hood!!
Kurt.
D TR2/3/3A oil pressure line venting? Triumph 4
R Bugeye oil pressure line Spridgets 9
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
K TR4/4A Oil pressure gauge Line? Triumph 5
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
Scotsman TR4/4A Replacement oil pressure line Triumph 5
M TR4/4A Oil pressure line from engine....assistance please. Triumph 9
fpstude TR2/3/3A Flex Oil Line to Oil Pressure Gage Triumph 5
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
T Oil Pressure Gauge braided line failure Austin Healey 6
mgbmedic TR2/3/3A oil pressure line routing TR3A Triumph 4
tmc Oil pressure line Triumph 6
tmc oil pressure gauge and line Triumph 5
C Oil pressure line MG 1
M Oil pressure line question ??? Triumph 8
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
71tr oil pressure sending line Triumph 5
JPSmit #3 Oil pressure line Spridgets 3
hondo402000 TR6 TR6 plastic oil pressure line Triumph 2
A Hot-low oil pressure / Aux. oil line problem fixed Triumph 6
jhorton3 Braided Oil Pressure Line Spridgets 12
Tinkerman TR2/3/3A Oil Pressure Guage Line TR3 Triumph 3
B Banjo Fitting - Oil Pressure Line Triumph 6
R TR6 TR6 Cylinder Head Oil Line effect on oil pressure Triumph 10
G Engine block oil pressure line fitting Spridgets 7
J Oil pressure line connection to oil filter post Triumph 1
tahoe healey oil pressure gauge line. Austin Healey 23
G Where does my oil pressure line connect? Spridgets 4
S Pressure Relief Spring & red line oil Austin Healey 13
B Oil Pressure Line Leak Austin Healey 4
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
