I assume the oil pressure pipe was attached to the oil filter housing ex factory....lower front bolt hole?
I cannot find the original bolt that accepts the banjo fitting [ I have the oilpipe/ line with the banjo fitting on the end].......is it a special bolt that allows it to screw into the block as well as accept the banjo fitting of the oil line?...a pic would be helpful.
Also, can the oil pressure pipe with a made up adaptor be fitted to one of the bolts/bolt holes that come out of the oil gallery.
