TR4/4A Oil pressure gauge Line?
karls59tr
Bronze
Anyone know where I could get the line/tube? that connects the gauge from the mid point connection up to the gauge? Actually I have the bottom part of the tube after the mid point but I am missing the female brass connector that attaches to the male end at the back of the gauge and about 2' of tubing. Is there a source for these connectors...appear to be fine thread.
TRF has the pipe listed, 202980.
IIRC the nut uses oddball threads.
Don't forget you need a seal between the end of the pipe and the gauge. Original was leather, but I used a small nylon flat washer instead. It should fit over the little nub on the gauge fitting.
