Hi Guest!
it been a long time since I had the oil pan off. what should i look at first. ? Can the cam shaft be pulled out with out pulling the engine?so is this a bad gauge or engine rebuild? I do not hear any knocking and engine runs just fine. opinions please
10 30 and then when it needs a qt I added 40 it is due for an oil change.Sim … what weight oil are you using?
Oh and I use 20W50 oil10 30 and then when it needs a qt I added 40 it is due for an oil change.
How old is you engine? Would this be too thick on new parts?Oh and I use 20W50 oil
My TF 1500 has had 20/50 Valvoline VR-1 ever since it was rebuilt, it runs 50lbs hot or cold. The relief valve is set at 50lbs. PJHow old is you engine? Would this be too thick on new parts?
I re-did the engine around 2010. I don't know that it would be too thick but probably Doc or someone with a bit more experience could chime in.How old is you engine? Would this be too thick on new parts?
ok ThanksOur local MG/Healey guru says they all need 20W50 and he has a lot of experience.
