sim
No have not changed any thing else. I did buy a cheep gauge but the fittings are not correct. But I just thought of a way to hook it up . I will try tomorrow and let you know. thanks for the info100, even at high rpm, would be too much. There is no way such pressure is actually possible at idle. The relief valve is irrelevant at idle because the pump could not generate the pressure to open it at idle.Try another gauge to ensure that the gauge is not the problem. I would run 10w30, although if you have a workshop manual that says otherwise follow the manual. What was the oil pressure condition before the low pressure cropped up? Have you changed any other components?
Bob
