TR4/4A Oil leak from rear of motor.
jimstr4
Here we go again, there's a leak from the rear of the motor.
I've flattened and straightened the sump and used RTV to seal it onto the block.
I've used a Marx seal on the rear of the crank.
I wiped the area in the photo and watched the drop reform, it doesn't come from the sump.
I used a camera probe to look up between the flywheel and I don't think that the rear seal is leaking so I think that it might be the camshaft plug.
The camera probe is too large to look up the that corner of the motor.
The photo is a view of the rear slave cylinder side of the motor.
Looks like the gearbox has to come out yet again.
TomMull
There is also an oil galley plug just outboard of the cam plug. But the transmission and flywheel need to come out in either case.
Tom
J
jimstr4
Thankyou for the reply.
My repaired overdrive/gearbox didn't seem to work so I thought that there might be a second reason to remove the transmission.
So I decided that the prudent thing was to top the tranny up and put the car on stands and try the overdrive again.
It doesn't work.
Two reasons to remove the gearbox is better than one or not..........
TomMull
Since the removal of the OD gearbox is somewhat of a pain it would be good to get both issues done at once. However, there are some things you can check with the transmission still in the car and it might be better to know what the problem is before tearing it down. Here is a discussion from Moss and there are others:
https://www.mossmotoring.com/tackling-triumph-overdrive/
Tom
mallard
With in inspection cover off I was able to get a small piece of a broken mirror that was taped to a rod to get a look up behind the transmission. I could see that the cam plug was indeed leaking. Easy fix with the trans out but the OD could be an other story. Good luck
mallard
Yes the one that is like half a circle at the bottom of the bell housing.
J
jimstr4
The good news was that I got the overdrive going after adjusting the Solenoid/ lever.
MY son and I removed the gearbox afterwards.
Seemed alot harder this time, I'm not looking forward to putting it back.
I have attached photos showing that the leak was from the camshaft plug.
The dark crescent shape on the flywheel is oil.
There is oil on the bottom of the rear main flange which doesn't extend up to the bronze bush.
The bronze bush is dry.
I'm assuming that the rear main oil seal isn't leaking.
I'm also assuming that the oil got flicked around from the camshaft plug.
Hmmmmm??????
Any opinions would be helpful.
Graham H
It looks like the camshaft core plug is dry the leak looks to be coming from the oil gallery plug which is at 7 oclock to the camshaft
TomMull
Agree. That plug is under pump pressure and is much more likely to leak.
J
jimstr4
Thankyou for the replies.
I thought the top one was the oil gallery plug, I got that wrong.
Yes the bottom one at 7oclock is leaking.
Is that a threaded Allen key plug.
Does mine look like a standard plug?
I've had a look at all my manuals but can't find any photos of that area plus I've looked at Moss Europe's online manual and they don't mention a part.
Neither do Rimmers.
If it's threaded I hope that it doesn't need retapping.
J
jimstr4
I've googled this problem and it seems to be a threaded aluminium Allen Key plug.
The only people who seem to list a part are Revington part no.: 056765
They suggest drilling out the old plug and using a threaded extractor which I assume will mean that metal swarf will end up in the engine necessitating the engines removal to clean the swarf from the oil galleries.
I'm hoping that mine will come out without drilling as the engine was recond.
I suppose that the thread might need retappng etc.
How have others fixed this problem
J
jimstr4
It's a steel plug and the threads look fine.
The gallery threads look a tiny bit scratched but nothing major.
DavidApp
A good quality thread sealer should do the trick. Or the brown shellac type gasket sealer on the threads. Clean the oil out of the gallery threads with solvent on a cotton swab/Q-tip.
David
Graham H
You should be able to re use that plug ,it just needs to be sealed,lock tight or PTF tape. Because its a parallel thread it hasn't got anything to lock onto,the original is a tapered aluminium plug that tightens as you screw it in.
J
jimstr4
It's the original plug, well it's the one that was on the engine prior to reconditioning.
The motor has been run a number of times without any oil leaks until recently, so the plug held for a while.
The parallel thread leakage makes sense.
I'm a bit paranoid as the current one took a while to start leaking and it's a pain to remove the tranny and put it back.
I suppose I'd have to reinstall it then attach the starter with short bolts to run the engine and test my repair.
I can buy a stick of aluminium ones I suppose.
DavidApp
It always amazes me how quick you can get answers from this forum.
This forum is a great resource. Not sure how people did it before the Internet.
David
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
S Rear crank seal oil leak BN2 Austin Healey 20
M Rear Oil Leak Spridgets 5
newmexTR3 TR2/3/3A tr3 head rear oil leak Triumph 9
J Oil Leak Thru Rear Seal? Spridgets 10
danielnorton Oil leak from rear wheel/axle Spridgets 17
Brosky TR6 TR6 Oil Leak at rear of head - [not really] Triumph 0
Brosky Oil leak from rear engine lift bracket bolts Triumph 2
W T-Series MGTD rear oil seal leak MG 7
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
I MGB Sprung an (oil) Leak! MG 2
B Oil (or Coolant) Leak Austin Healey 10
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
B Phanton Oil Leak Spridgets 12
I Bugeye oil leak help Spridgets 4
Zitch Engine Oil Leak After Long Drive Austin Healey 19
2 TR2/3/3A Oil leak in tranny Triumph 4
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
steveg Strange Oil Leak Austin Healey 7
TomMull TR2/3/3A Transmission oil leak Triumph 17
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
D BT7 Oil Leak at Distributor Austin Healey 5
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T Oil pan leak? Spridgets 7
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
C oil leak Spridgets 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR2/3/3A Locating source of oil leak Triumph 6
Jim_Stevens TR2/3/3A Trunnions oil leak Triumph 2
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
Martinld123 Problems with Oil Leak From Distributor Austin Healey 2
T TR2/3/3A coil mounting bolt oil leak Triumph 2
4tecdog BJ8 Overdrive oil leak Austin Healey 6
H blow by oil pressure causes oil to leak out of the dip stick tube. Austin Healey 12
TulsaFred Front engine oil leak Spridgets 33
TulsaFred Fixed One Oil Leak, Found Another! Spridgets 12
Sixpack TR6 Bad Oil Leak Triumph 24
T Gear Oil Leak Austin Healey 17
Rut Bugeye oil leak Spridgets 8
J Found an oil leak Austin Healey 7
V Problems - Oil Leak and Manifold Pressure Austin Healey 1
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
J Engine block modification for oil to water jacket leak Austin Healey 8
apbos We have Vroom, Vroom and an oil leak from the Oil Filter! Spridgets 11
