TR6 Oil filter relocate kit
OldGuy51
Has any one replaced the original oil filter and canister to a relocation kit . So the filter is vertical and say mounted to the fire wall or driver fender for ease of changing. Do you have a model or part # for the kit ? Thanks Frank
Gliderman8
Moss Motors sells an adapter that replaces the canister with a screw on filter. The adapter mounts where the canister came off of.
ed_h
If the main thing you want is for the filter to be vertical, it's possible to do it on the engine, but not easy.
Ed
O
OldGuy51
Not so much being vertical only but where it is moved from to an open space. One piece goes on the block and two braided lines say go to the inner fender where the new spin on is located on another block
charlie74
I have never seen an off-the-shelf arrangement like what you are describing. Maybe something could be fabbed up using an external oil cooler kit…
ed_h
You can easily buy the remote filter fixture and the lines. The hard part would be the adapter on the block. Might have to be custom.
Ed
O
OldGuy51
What I bought was the 90* spin on filter adapter. that bolts to the block and references the spin on PH8A filter to lay against the block facing the front of the car. I I choose to relocate with hoses and another filter block , it will screw onto the spin on adapter where this filter goes and the remote block can be mounted anywhere the hoses can reach. Thank you all for the responses OG
SpitfireGT/V
Sorry, new to forum. The part you are looking is made by ThinkAuto (MOCAL). P/N: TOPO6
Ask for Nick Fitzgerald. I bought mine for him so he will know what you are asking for.
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
Simmo MGA OIL FILTER MG 3
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
H 280i oil filter TVR 2
R Oil Filter Removal Austin Healey 1
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
Simmo TR2/3/3A Oil filter Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
F Which Original Oil filter assembly for BN7 Austin Healey 19
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
T Oil filter block plate - really? Austin Healey 13
Raymond MGB 1969 oil filter MG 4
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
D Oil Filter Bolt Seal Austin Healey 2
C For Sale oil filter adaptor and canister Austin Healey Classifieds 0
T TR6 Spinon Oil Filter Adapter Triumph 3
K TR4/4A Look what I found in a 4A oil filter? Triumph 14
H Spin-on oil filter for BJ8 Austin Healey 26
D TR4/4A extra long oil filter attachment stud Triumph 9
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
M TR2/3/3A After Market Oil Filter - TR3B Triumph 8
Marla TR4/4A New oil filter Triumph 7
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
M Reaching the oil filter Spridgets 14
B Question about Oil Filter Orientation on Early 100-6 Austin Healey 4
M Oil filter on Bugeye question Spridgets 4
R Oil flow to filter Austin Healey 5
Michael Oritt Royal Purple oil filter Racing 6
Michael Oritt Royal Purple oil filter Austin Healey 3
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
R Which oil filter base on my BJ8 Austin Healey 8
jfarris TR2/3/3A Which Oil Filter Triumph 3
toysrrus TR2/3/3A Oil Filter Adapter question Triumph 15
C new engine - oil pressure blowing filter seal Austin Healey 12
apbos We have Vroom, Vroom and an oil leak from the Oil Filter! Spridgets 11
