Oil Filler Cap-Retaining Wire
gsable
Hi Guys,
You know you have made progress when you focus on a broken retaining wire for the oil cap.
My wire is broken. Can anyone tell me how to repair or replace it? It appears to be soldered to a groove in the filler neck.
What is a suitable replacement wire and how do you get the wire out of the cap?
Help is much appreciated.
Gary
John_Progess
If it is broken at the filler neck that can be fixed by soldering/brazing a small dob on the end just big enough so it will form a sholder in the groove. As for the cap, it will have to be dissassembled (never done that) or just braze the wire at the break. Have a good day!
John
andybj8
Gary
An alternative way is to cut the plastic of a spade connector, snip the small metal tube off (that the wire is usually crimped into)then just slid this over the wire and crimp. You can easily use this on both ends, and its very easy to use a screwdriver to prise open the slot in the filler neck, put the end in and squeeze closed with a pair of pliers.
Cheers Andy
Genos2
I've got perhaps 1/2 dozen or more v/covers in my basement,most complete or at least w/filler caps, should I dig them out& check condition? Or should I separate . Are they not available? Guess I've been out of touch,what are they worth? cheers Genos2
gsable, congrats. on your progress, the guys have given you good ideas on how to repair the cable, a new cap with cable from moss motors is about $14.00, i recall being able to buy just the cable from a moss distributor here in ct. 4 years ago, think it was $2-$3. :savewave:
I've got the opposite problem. Cap and wire are good but the rivited piece that the wire goes into is loose. Any magic to re rivit it. Not a lot of room on the inside of the tube to hammer against. Pop rivits look tacky. JB weld is my next thought.
th, on my bj7 they didnt use rivets, the bracket/fixture is spot welded to the spout at each end, yours may have been rivited by a p.o. or the model car you have used rivets, if i had to, id just use small, soft aluminum pop rivets, is this the area your talking about?, --- aha!, just looked at your profile and "see" -:crazyeyes: you own a bj8, i dont know if rivets were used on them. :savewave:
Thanks, Anthony. You may be right. The PO did lots of "interesting" things. Is the loading hole to the front or the back. Yours appears to be forward while mine is to the rear.
G
gsable
TH,
Anthony may have a BJ7 but his comments are correct for a BJ8. The retaining bracket on the neck of the filler tube on my BJ8 is spot welded, not riveted. The PO strikes again.
gsable
gsable, oh my goodness!! are you telling me i have a none original valve cover on my bj7?, i cant believe it! ive been duped!, i wont be able to sleep for a month, oh the humanity!..my heart is crushed!, im gooing right out to the shop and remove it and wait till dark to toss in the trash in a box so the neighbors cant see it, thanks for the info..
i didnt remember i replaced the original 4 years ago with a cleaner one i got off ebay, wow its gettin so i cant remember what i had for breakfast...did i even have breakfast?.....
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
bighealeysource Looking for a 100-4 valve cover oil filler cap Austin Healey 0
brgrmyster GT6 Original AC oil filler cap 67-68 GT6 [also TR4A]? Triumph 1
K oil filler cap Spridgets 0
V TR2/3/3A TR-3B Oil Filler Cap Triumph 5
CharlieCarpenter Gasket for oil filler cap??? Austin Healey 1
AUSMHLY Does the oil filler cap have a seal? Austin Healey 1
davidk Chrome oil filler cap Triumph 9
H OIL FILLER CAP Austin Healey 1
ncbugeye Smog oil-filler cap Spridgets 3
curtis oil filler cap Triumph 5
Wana Oil filler cap - gasket? Austin Healey 9
andrea OIL sprayed on the under hood-TOP oil filler indaghed Austin Healey 26
J location of transmission oil filler on a BN-2 Austin Healey 5
J What should I feel at oil filler pipe? Triumph 14
Tabcon Okay...who poured green paint in my oil filler! Triumph 16
H MGB-GT Where is the gearbox oil filler plug on a 67 GT? MG 3
Wana Oil seeping around filler neck? Austin Healey 7
S Transmission oil filler where is it? MG 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
