Oil catch tank
My catch tank vents to atmosphere via a filter. Why would you want to direct this stuff back into the intake system?
I'll bite: So you're not dumping it into the air we all breathe (why engines went from 'road draft' tubes, to carburettor tubes to PCV systems; most cars still use PCVs, for the same reason). It's generally agreed that combusting blow-by gasses is at least marginally less harmful than dumping them into the atmosphere (which may be true only if you have a catalytic converter, but the thought counts).
I think, ideally, you have an 'oil-air separator'--i.e. a catch can--and a PCV. I put a separator on my Mustang GT, it traps about a teaspoon of oil every thousand miles.
steveg
Not only is Adrea's easy to empty, it has a sight glass to see whether it even needs to be emptied!
The Ducati Diana has a built-in recycling road draft tube - reaching from the engine to the tail light. This allows vapor to condense and run back into the engine.
andrea
steveg; The Ducati Diana has a built-in recycling road draft tube - reaching from the engine to the tail light. This allows vapor to condense and run back into the engine. [ATTACH=CONFIG said:
59040[/ATTACH]
Hi Steve
Long time ago I have one similar to this 175 cc model DUCATI "CALIFORNIA" because have the seat fringed as Western and a knees protection with two chromed clack sons a poor imitation of Americans Motorcycles- but a strong and reliable motorbike
M
mgtf328
Andrea, RAC68 suggested in a previous post that the can should be mounted high enough to avoid the possibility of initiating a syphoning effect. I can't personally see how you could drain the sump this way but I was wondering whether you took any precautions and what your experience is mounting the can so low.
AJ
John Turney
AJ
If the can is connected to the T at the top of the valve cover, one won't get syphoning. If the can is connected to the vertical pipe from the side cover to the T, much more oil will be collected in the can. One of my experiments showed that.
John Turney
John,
So, what did you do for pressure relief and venting of the rocker cover?
Lin
Hi Lin,
That was one of my PCV experiments. Most PCV valve installations, including my early one, don't have a filtered air inlet.
So, I put a small vent filter on one leg of the T atop the rocker cover with an orifice behind it for an air inlet. The other horizontal leg of the T was blocked, so that air would enter the T, go into the rocker cover, down around the push rods to the crankcase. I had a hose off the vertical pipe that normally goes from the side cover to the T that went to the oil catch tank and then to the PCV valve.
Anyway, the catch tank collected a lot of oil, so that idea was abandoned.
andrea
23400002_FOTOFITXA_A_valvula-anti-sifon-cubierta-interior-imnasa-ref-23400002-A.jpgHi MGTF
I considered that the air filter on the TOP of the can catch tank can avoid the siphon problems -that can appear only in presence of LIQUID VACUUM in the OIL circulation - Engine OIL level are lower - and on the pipe we have only oil vapors that then condenses in the catch
However your observation can be correct , and I seriously consider the add of a little air inlet valve near the top T joint -
BUT catch can was applied some Years ago and no siphon problems was observed during this time
Deleted member 21878
i added the filter at the side cover/verticle vent pipe. my verticle vent pipe is plugged so nothing gets pulled thru it. the side cover now just lets air in. all the vaccum comes out the valve cover. it is my understanding that allowing fresh filtered air into an engine is a good thing for the metal parts and the oil.
To control the amount of air and also the amount of vaccum inside the engine, i bought a small paint gun valve from HF. then i hooked up my system and ran the car. i turned the valve control to get the vacuum to no more than 1" of hg. probably should even be less but hard to get a good reading below that. when i changed the oil last time, i could hear air being pulled thru the filter while draining the oil.
after the valve was set, i watch the reading over various RPM's. the reading of 1" never changed.
if you look closely you can see the filter down in the right bottom corner of the pic. it is kind of hidden behind the frame.
FWIW, in normally-aspirated aircraft--with both manifold pressure and ambient air pressure readings available--engines always pull at least 1" of Hg negative air pressure (i.e. 'vacuum'), even at WOT. Some highly-tuned engines may be less, but a 1" pressure loss in the manifold and throttle is pretty much a truism.
H Oil Catch Tank Austin Healey 10
C TR2/3/3A Oil Catch Can TR3a Triumph 8
theleisure TUDOR Washer Bottle Look-a-Like Oil Catch Can Spridgets 3
3798j TR4/4A Added an Oil Catch Can Triumph 8
RAC68 OIL...CATCH it if you CAN Austin Healey 13
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
