OD drop out at lower speeds
twigworker
Curiosity here...I have driven, shall we say several, LBCs equipped with both the D and LH OD units over the years and I cannot recall any of them "dropping out" of OD at lower speeds as noted in a thread below. If I squint my eyes and screw up my nose I might be able to make myself believe that certain AH 3000s did but I would probably be making that up based on the throttle position relay out under the hood. In my present B and all of the ones that I have driven lately the OD will work in the top two gears no matter at what road speed the car is moving. I am presently going through a black label LH unit and see nothing that would have any such control, either internally or externally VIA an electrical device. The only thing that I can think of would be a drop in hydraulic pressure when the pump is not working particularly fast in conjunction with the use of a light lubricant such as ATF or 5W or synthetic oil, which of course is a no-no. Perhaps in that case the cone clutch release springs might over ride the available pressure and release the clutch but who knows? If someone can further enlighten me on this I would appreciate it. Jack
BoneIdle
Jack.
I recently had a problem in 1st and 2nd that appeared to be the opposite of what you describe: Overdrive wasn't releasing fully and the two lower gears would occasionally cease to function momentarily. Serviced the transmission and OD ( drained and cleaned ) and everything seems to work fine now. I'm suspecting the thing hadn't been cleaned in 20 years or so. When I refilled the trans and OD I used 15/40 Rotella T. I have noticed that while I feel no ill effects from the Rotella, that the sizzle in the gearshift knob has quietened down. I'm gonna drain the whole thing again in about 400 miles because I'm curious about how much sludge is still in the system.
As a weird aside, Doc Entropy and I checked the fluid level before I left Tampa and aside from being a little low, the oil was unbelievably clean ( like new ). When I did the service , the oil was black as pitch. I'm wondering now if the stuff up top was never getting into the sump due to sludge.
jlaird
Cleanlyness is next to Godlyness.
tony barnhill
Great Pumpkin - R.I.P
OD should drop out in an MGB when your speed goes below 45 (I think that's the cutoff)
BoneIdle
[ QUOTE ]
[/ QUOTE ]
yep! And I found a new one:
The quickest way to a man's doghouse is through his greasy hands! /ubbthreads/images/graemlins/devilgrin.gif
T
twigworker
That is strange Tony. Not disputing what you say or if it "by the book" or not, I just haven't ever encountered the drop out on a B. In fact, since I am clumsy and forgetful and drive like a sissy I will often cruise into town in 4th OD and forget to snap the transmission out of OD when I roll up to a stop sign. Then, when I begin to accelerate again when I go into third it is boggy because it is still in OD and I have to very quickly clutch it to make things smooth as I flick back into "normal".
What is it in the OD unit that does the automatic kicking out at 45 or below? I can't see anything other than the spring pressure/hydraulic pressure over ride as noted earlier.
Dear Bone Man,
As far as dirty lube is concerned the stuff that came out of the transmission that I am rehabbing was weird too. Of course there isn't supposed to be much discoloration of the lube simply because there is no combustion process going on that would contaminate it. The only thing that one might expect is perhaps something caused by condensation trickling down the walls of the case and mixing with the oil to cause a light color change but that should be extremely rare. The only other source of "blackness" that I can think of would be the overheating and deterioration of the cone clutch in the OD unit, and that could be caused by extreme use or low fluid level. The one I am into right now had "sort of clean" clean fluid but there was lots gunk in the hydraulic passages traceable to the completely trashed speedo spindle gear and output shaft speedo gear. They simply weren't there any more.
One extra note...I have used gear oil in OD transmission off and on for eons but it struck me the other day that it might not be a good idea to have it in there in cold weather. I was looking at the drain back ports in the bottom of the OD unit and I thought of all of that thick fluid doing it's best to wriggle through the small openings without a pump behind it to get it to move. All I could envision is a sort of damming effect and that the fluid would accumulate where it really shouldn't be and not be where it should, out front and lubing the gears and bearings themselves. After reading and actually thinking about all of this recently I believe that I have talked myself into a strict diet of either a reasonable multigrade engine oil or a straight non-detergent 30 wt.
Jack
Steve_S
I've never experience an OD dropping out at lower speeds either. I do currently have an issue where I have to hold the gear shift lever to the side to get the OD to stay engaged, but that's a separate issue.
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Basil Drop Stop Restoration & Tools 3
AUSMHLY HD8 drop test time in seconds Austin Healey 3
H BJ8 jet drop measurement Austin Healey 8
Morris Price drop Spridgets 1
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
T TR2/3/3A SU Piston Drop Test Triumph 4
Basil Jag XK120 Drop Head Spotted 2
steveg Heater Blower voltage drop Austin Healey 8
drambuie Austin Healey Abbott drop head coupe Austin Healey 15
aeronca65t MGB MGB-Helo drop MG 5
Steve P. T-Series MGB-GT trailer hitch for tear drop trailer? MG 8
tahoe healey OD drop out Austin Healey 9
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
TRclassic3 Slow idle drop Triumph 8
R Rapid oil pressure drop Triumph 14
H Should I drop the front end down a little? Austin Healey 25
A Headlight Voltage Drop MG 5
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
AUSMHLY Do your RMP's drop when at idle with clutch in? Austin Healey 11
zimmy 74 midget..............final price drop! Spridgets 7
mountainman Removing Drop Arm From Sterring Box Triumph 7
K TR2/3/3A TR3 Steering:Nut that attaches drop arm........... Triumph 2
Scott_Hower MGB MGB sump removal .. must I drop the xmember? MG 13
jvandyke high load drop out Spridgets 41
W T-Series Idle drop when the clutch is in MG 10
F Spitfire Spitfire pushrod drop? Lifter/ Cam?? Triumph 12
mine TR2/3/3A Price drop on almost complete TR3a going to ebay Triumph 4
Rick60 Drop in idle when operating clutch Austin Healey 13
T TR4/4A TR4 - Sudden Oil Pressure Drop Triumph 9
A Heat in engine bay causes idle to drop? MG 37
healeyboz Just about ready to drop in the motor and tranny Spridgets 14
JamesWilson Healey Abbott Drop Head Coupe: for sale, e-bay UK Austin Healey 3
Harry_Ward TR2/3/3A TR3 idle speed drop Triumph 7
Webb Sledge DHC [Drop Head Coupes] Triumph 19
Lynn Kirkpatrick T-Series RPM drop when depressing clutch MG 9
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
