Is there a known supplier for O rings or flat gaskets that fit between the glass and chrome faces of instruments? I haven't found anything other than sizeable thin O rings. PJ
Paul, the o-ring gaskets found in the canister type oil filters work if you can't easily find "correct" ones. Cutting the oil filter gaskets with a razorblade to correct diameter and using "super glue" to reattach the ends. Used 'em for decades as such, set the seam to the bottom of the gauge if it's noticeable at all. Think: splicing recording tape or movie film. The joint is usually unnoticeable if you're careful.
And usually the gaskets are "free" in that there are a couple in each filter box.
