    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
O.K. Boys , What's Your Choice?????
BOBBYR
Good Evening Boys,
After nothing but problems with the last fuel pump I ordered, it's time to order the right pump.I've decided to order from Moss, so here's the problem.(You guys need this like a hole in the head.) My healey is a 1965 3000 mkIII number BJ8L28972.It is a original,pos. ground charging system.
Should I order the original point type fuel pump,or should I order solid state? Keeping it original means alot to me ,but I also want it to be dependable.What do you think boys?I value your opinions and thanks for your help.Have a good night.
Bobby R
GregW
I went with the solid state one. For no particular reason.
Dave Richards
FWIW, IMHO...
I stayed with the points type original when I bought a new pump last year. Brit Bits I like to hear the clicking from the pump, it brings back good memeories, and some great stories about the times when the clicking stopped! That means something to me, maybe not to others, it's my car and it makes me happy.
That being said, if it's not clicking, I can get under the car and usually make it go. The points have their issues, you just have to be aware of what they are and be prepared to deal with them.
The technology is 50 + years old and I enjoy the fact that I can usually deal with the failures, and eccentricities of the technology. It makes me feel good driving (and repairing) it ... /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
AUSMHLY
My vote is for the modern solid state. One less thing to have to worry about. Plus it still has the clicking sound like the original.
I also recommend upgrading the points in the distributor to a Pertronix. One less thing to have to tune, it's invisible and problem free.
Nice thing about both units, is your car still looks stock.
Cheers,
Roger
GregW
Hi Dave,
Not trying to change your mind, but my pump makes the noise of which you speak. A couple of glug glugs that slows then stops as the pressure comes up (assuming no fuel leaks). I have the SU solid state negative ground, Moss part # 377-255
Randy Harris
My original fuel pump finally bit the dust last year. I replaced it with a solid state unit that looks and sounds just like the original unit. The installation was a snap. So far it has operated flawlessly. YMMV.
Randy '66 BJ8
TomFromStLouis
I think your answer depends on your ability and willingness to deal with the issues that arise from 50 year old technology. If you are able (willingness I assume by your owning the car), let your preference for originality be your guide. Otherwise, this is not the kind of change that cannot be reversed.
Dave Russell
Yoda - R.I.P
Bobby,
Your car originally had an AUF301 pump which used a non polarity sensitive capacitor for point arc suppression. Later replacement pumps were the AZX series with diode point arc suppression & WERE polarity sensitive.
I believe the newer Moss #377-245 is electronic, no points, is polarity sensitive, positive ground. It is the closest to original in a modern pump. Since they still have the reciprocating diaphragms, they do still make a clicking noise.
BOBBYR
BOBBYR
Hi Gang,
Thanks for input and for the part numbers.I think what I'm going to do ,is go with the solid state and rebuild the original.A friend of mine told me not to throw away any old parts while putting the healey together, so this should cover the problem both ways.These Healeys can drive you crazy,but what a way to go! Thanks Gang,
Bobby R
roscoe
I like the clicking too. Especially when you are sitting at idle, just drove to a friends place of business to show it off, and all of a sudden the clicking gets real fast. You have about 20 seconds before you flame out. A working fuel gage really fills in for a memory that doesn't always (work).
judow
Darth Vader - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif and so does Agatha A Healey.
MadRiver
Bronze
I tend to favor the good old stuff. Both Healeys and the MG have original style fuel pumps. The Triumph does as well, but it's a manual unit on the block. I recently bought a good old fashioned fuel pump to replace the modern square thing the PO put on my Sunbeam.
Lin Nasty Boys Article Austin Healey 14
BlueMax The F1 Boys Are Riding In Style!!! Spridgets 5
HealeyRick Hangin' With the Big Boys Other British Cars 1
HealeyRick Behind the Ton Up Boys British Motorbikes 0
RickB Boys out in the Midget Spridgets 2
Gundy Little Frogeye w/ apologizes to the Beach Boys Spridgets 5
rkep01 Here's one for you FLA boys Spridgets 15
tahoe healey lost boys Austin Healey 10
Tabcon Big Brake Kits for Big Boys. Triumph 7
Hap Waldrop All the boys on the WWW Spridgets 8
Tabcon The Hardy Boys and The Mystery of the Stromberg Triumph 5
Brosky TR6 Sweet TR6 hardtop for the Louisiana boys Triumph 0
KindredSpirit Ballyvaughan Old Boys Christmas Run. Other British Cars 49
Bret Well them Dodge boys finally went & did it! Other Cars 4
aeronca65t BARC Boys Racing 3
B Nasty Boys! Triumph 7
sparkydave Smokin' in the boys' room and a holy filter... Spridgets 9
bash TR6 TR6 LUK Clutch kit from Autozone/Pep Boys? Triumph 3
jaybird Okay boys, gonna need your help! MG 101
soren_ak Hi Boys and girls culd u give me your thoughts on= Austin Healey 1
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
B TR6 TR6 1976 Clutch Choice Question Triumph 3
JPSmit Lots of choice! Spridgets 0
N Best cam choice??? Spridgets 5
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
D TR2/3/3A starter choice Triumph 15
BOBBYR Steering wheel choice Austin Healey 20
BOBBYR oil pump choice Austin Healey 5
5 TR2/3/3A TR3 Color choice? Triumph 29
Hap Waldrop MGB A new alloy wheel choice for MGBs MG 11
tri_carb_healey battery choice!? Austin Healey 4
Lin Attention Dougie - racing video camera of choice Austin Healey 8
drooartz MGB MGB Top Frame Choice MG 10
Rut muffler choice Spridgets 15
H Challenging myself on wire wheel color choice Austin Healey 22
mikecyc72usa Personal choice over originality MG 20
Sherlock Car shopping and a tempting choice... Other Cars 19
M Color Choice Spridgets 16
D Electronic ignition choice[s] Triumph 17
M_Pied_Lourd TR2/3/3A TR3A Front Brake Caliper Choice Triumph 5
mountainman Electric Fan Choice? Triumph 3
F GT6 GT6 diff choice for O/D Triumph 11
C Steering Wheel choice Austin Healey 17
T Wedge Wedge options wanted - interior choice poll! Triumph 9
I TR6 69 TR6 suspension spring choice? Triumph 7
BOBBYR Dwell meter choice? Austin Healey 1
PAUL161 Collectors Choice Oil 20/50 from Moss with ZDDP! MG 10
athenssprite Battery choice - 1960 Bugeye Spridgets 1
T TR2/3/3A TR3A piston choice question Triumph 3
healeyboz cam choice Spridgets 19
