tomshobby
This is a list of about 90$ to 95% of the fasteners for the engine bay with SKU numbers from Fastenal. It includes some for the engine, motor mounts, trans to engine, pressure plate and a few others. It also includes items for the braces. You can see some of the pics I posted and get an idea of what this list covers.
This is a guide and you may want different grades than I used. Also a half dozen are 1/8 too long because there were none listed for the correct length.
Hope this is helpful. Sorry for the long post but I was not sure how to make a file available.
Line No. Qty Description Qty/Pkg Ext Qty Price Total
1 6 3/8 Zinc Plated High Collar Lock Washer Sku: 0129170Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.1252 $0.75
2 20 3/8"-24 Grade 8 Plain Finish Hex Full Nut Sku: 36455Status: Line Item AcceptedEst. Delivery Date: n/a 1 20 $0.107 $2.14
3 2 5/16"-24 x 7/8" 18-8 Stainless Steel Hex Cap Screw Sku: 70087Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.7499 $1.50
4 2 5/16"-24 Hex Full Nut 316 Stainless Steel Sku: 77731Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.3533 $0.71
5 30 5/16 SAE Flat Washer zinc plated DOMESTIC Sku: 0159722Status: Line Item AcceptedEst. Delivery Date: n/a 1 30 $0.0287 $0.86
6 50 3/8" Zinc Plated SAE Flat Washer Sku: 1133082Status: Line Item AcceptedEst. Delivery Date: n/a 1 50 $0.0412 $2.06
7 6 M6-1.0 x 22mm 8.8 DIN 933 Full Thread Zinc Hex Cap Screw Sku: 38560Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.1646 $0.99
8 6 3/8"-24 x 1-1/8" Grade 5 Zinc Plated Hex Cap Screw Sku: 17106Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.2152 $1.29
9 2 5/16"-24 x 5/8" Grade 5 Zinc Plated Hex Cap Screw Sku: 17052Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.1244 $0.25
10 10 5/16"-24 x 1-3/4" Grade 5 Zinc Plated Hex Cap Screw Sku: 17060Status: Line Item AcceptedEst. Delivery Date: n/a 1 10 $0.1993 $1.99
11 4 10-32 x 3/4" Phillips Round Head Zinc Plated Machine Screw Sku: 29060Status: Line Item AcceptedEst. Delivery Date: n/a 1 4 $0.0262 $0.10
12 100 1/4" Zinc Plated Medium Split Lock Washer Sku: 33618Status: Line Item AcceptedEst. Delivery Date: n/a 1 100 $0.0113 $1.13
13 100 5/16" Zinc Plated Medium Split Lock Washer Sku: 33620Status: Line Item AcceptedEst. Delivery Date: n/a 1 100 $0.0173 $1.73
14 100 3/8" Zinc Plated Medium Split Lock Washer Sku: 33622Status: Line Item AcceptedEst. Delivery Date: n/a 1 100 $0.0226 $2.26
15 10 3/8" Zinc Plated Internal Tooth Lock Washer Sku: 33713Status: Line Item AcceptedEst. Delivery Date: n/a 1 10 $0.0375 $0.38
16 10 #10-32 Low Carbon Zinc Plated Machine Screw Nut Sku: 36030Status: Line Item AcceptedEst. Delivery Date: n/a 1 10 $0.0226 $0.23
17 50 1/4-28 Grade 5 Zinc Plated Full Hex Nut Sku: 36352Status: Line Item AcceptedEst. Delivery Date: n/a 1 50 $0.0349 $1.74
18 50 5/16-24 Grade 5 Zinc Plated Full Hex Nut Sku: 36354Status: Line Item AcceptedEst. Delivery Date: n/a 1 50 $0.0506 $2.53
19 6 5/16-24 Grade 8 Plain Finish Full Hex Nut Sku: 36453Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.0688 $0.41
20 50 3/8"-24 Grade 5 Zinc Plated Hex Full Nut Sku: 36356Status: Line Item AcceptedEst. Delivery Date: n/a 1 50 $0.073 $3.65
21 20 5/16-24 Zinc Plated Nylon Insert Jam Lock Nut Sku: 37123Status: Line Item AcceptedEst. Delivery Date: n/a 1 20 $0.0609 $1.22
22 2 5/16" 18-8 Stainless Steel Medium Split Lock Washer Sku: 71065Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.0965 $0.19
23 2 5/16" x 3/4" T316 Stainless Steel Flat Washer Sku: 78015Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.1619 $0.32
24 30 1/4 Zinc Plated SAE Flat Washer Sku: 33078Status: Line Item AcceptedEst. Delivery Date: n/a 1 30 $0.0226 $0.68
25 30 #10 Zinc Plated SAE Flat Washer Sku: 33074Status: Line Item AcceptedEst. Delivery Date: n/a 1 30 $0.0187 $0.56
26 4 3/8 Zinc Plated SAE Flat Washer Sku: 33082Status: Line Item AcceptedEst. Delivery Date: n/a 1 4 $0.0412 $0.16
27 6 M6-1.0 DIN 985 Zinc Plated Nylon Insert Lock Nut Sku: 40155Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.0755 $0.45
28 8 5/16"-24 x 1" Grade 5 Zinc Plated Hex Cap Screw Sku: 17055Status: Line Item AcceptedEst. Delivery Date: n/a 1 8 $0.1418 $1.13
29 9 3/8"-24 x 7/8" Grade 5 Zinc Plated Hex Cap Screw Sku: 17104Status: Line Item AcceptedEst. Delivery Date: n/a 1 9 $0.1833 $1.65
30 1 5/16"-24 x 1/2" Grade 5 Zinc Plated Hex Cap Screw Sku: 17051Status: Line Item AcceptedEst. Delivery Date: n/a 1 1 $0.1212 $0.12
31 6 5/16"-24 x 1 1/4" Grade 5 Zinc Plated Hex Cap Screw Sku: 17057Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.1514 $0.91
32 8 3/8"-24 x 3/4" Grade 5 Zinc Plated Hex Cap Screw Sku: 17103Status: Line Item AcceptedEst. Delivery Date: n/a 1 8 $0.1674 $1.34
33 10 5/16"-24 x 1-1/2" Grade 5 Zinc Plated Hex Cap Screw Sku: 17059Status: Line Item AcceptedEst. Delivery Date: n/a 1 10 $0.1753 $1.75
34 6 1/4"-28 x 1/2" Grade 5 Zinc Plated Hex Cap Screw Sku: 17001Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.0797 $0.48
35 2 1/4"-28 x 5/8" Grade 5 Zinc Plated Hex Cap Screw Sku: 17002Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.0845 $0.17
36 6 5/16"-18 x 7/8" Grade 8 Yellow Zinc Hex Cap Screw Sku: 15054Status: Line Item AcceptedEst. Delivery Date: n/a 1 6 $0.1345 $0.81
37 2 3/8"-24 x 2" Grade 5 Zinc Plated Hex Cap Screw Sku: 17111Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.3267 $0.65
38 2 5/16"-24 x 3/4" Grade 5 Zinc Plated Hex Cap Screw Sku: 17053Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.1275 $0.26
39 4 10-32 x 1" Phillips Round Head Zinc Plated Machine Screw Sku: 29072Status: Line Item AcceptedEst. Delivery Date: n/a 1 4 $0.0312 $0.12
40 14 1/4"-28 x 1 1/8" Grade 5 Plain Finish Hex Cap Screw Sku: 16006Status: Line Item AcceptedEst. Delivery Date: n/a 1 14 $0.1037 $1.45
41 50 3/8-24 Zinc Plated Nylon Insert Lock Nut Sku: 1137124Status: Line Item AcceptedEst. Delivery Date: n/a 1 50 $0.113 $5.65
42 3 3/8-24x1-3/8 Zinc Fine SAE J-429 Grade 5 Hex Cap Screw Sku: 0149837Status: Line Item AcceptedEst. Delivery Date: n/a 1 3 $0.4838 $1.45
43 100 #10 Zinc Plated Medium Split Lock Washer Sku: 33614Status: Line Item AcceptedEst. Delivery Date: n/a 1 100 $0.0094 $0.94
44 2 3/8"-24 x 1-3/4" Grade 5 Zinc Plated Hex Cap Screw Sku: 17110Status: Line Item AcceptedEst. Delivery Date: n/a 1 2 $0.2868 $0.57
Subtotal $49.74
Shipping & Handling $8.62
Add any state and local tax for your area
Subtotal $49.74
