Nut size for BJ8 center console trim piece
Johnski3000
Does anyone know the nut size for the center console trim pieces? there are 6 nuts per trim piece strip. Diameter looks like a #4 but it must be a fine thread or another size since a 4-40 does not work. If you know of a source for them as well, it would be appreciated.
Johnski
steveg
Johnski,
Are you referring to the little pins such as at item #120? Moss page: "Instruments, Switches and Dash BJ8" says they are clips, unavailable and to use your originals.
If they are indeed screws and a 4-40 is slightly too small, you could try the rare 6-40. Almost all the threads on 6 cyl Healeys are fine threads. Some 6-40s are available on eBay and from Grainger.
Suggest calling British Car Specialists in Stockton or Healey Surgeons. They should be able to help.
You could try measuring the stud or screw major diameter per chart below.
J
Johnski3000
Thanks, saw the Moss / original parts chart, it does not show a nut of any kind. I had screws and not clips on my console. I found a source for a #4-48 which would be the fine thread. If that does not work, I will come up with some other scheme.
GregW
My BJ8 came with tee-head screws that can slide inside the trim piece to line up with the holes in the console. Something like this.
RTaillieu
My '64 BJ8 Phase 1 has bolts and nuts.
J
Johnski3000
My 1965 early phase 2 car (one tail / directional light but other phase 2 stuff) had the nuts and threads. Maybe they switched to clips for later phase 2 cars. Makes sense based on how fiddly it was to get the nuts back on.
John
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
R Vixen 2500 Lug Nut Size? TVR 5
C Size of axle bearing nut Austin Healey 11
GeorgeC Steering wheel nut size? Spridgets 3
Rut TR4/4A steering shaft/nut thread size Triumph 5
M 948 Pulley Nut Size Spridgets 1
RJS TR4/4A Rivet-Nut Size Triumph 0
J MGA MGA rear axle bearing nut size MG 0
M Front Bumper Nut size Spridgets 2
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
abarth69 Early BN1 Axle Nut Size Austin Healey 1
C Hex. nut size? Austin Healey 1
Tinkerman Starter Terminal Post Nut Size Triumph 14
S What size is your nut?? MG 3
M steering wheel nut size. Triumph 10
boxfullofyertoys Rear hub nut size Spridgets 10
bcliff Spindle nut size? MG 2
budk1953 Steering wheel nut size Spridgets 2
Bruce_B Size of Nut for Steering Wheel..driver not include Spridgets 6
tahoe healey starter nut size Austin Healey 6
B 1500 Crank Nut Size? Spridgets 15
chicken What size spanner for the crankshaft nut Austin Healey 5
D rear hub nut size? MG 11
73MidgetLigon Lug nut size for 73 MG Midget Spridgets 2
Baz Brake pipe nut size? MG 13
mbrooks 100-4 crankshaft nut size? Austin Healey 1
2wrench Describe thumb nut size and thread on speedo stud Triumph 26
vping Size of my nut... MG 17
T Mini drive shaft nut size. British Motor Corp 2
mbrooks BN2 front wheel hub nut size? Austin Healey 1
Patton Cap Nut on H4 SU Lid Size? Austin Healey 11
B MGA Where to Buy, What to Buy? Axle Nut MG 9
C Steering Arm Castle Nut Torque Austin Healey 5
B General MG Crankshaft Nut Removal MG 4
drooartz Modifying castle nut Restoration & Tools 3
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
G Stator Tube Nut and Olive Austin Healey 9
dbenichou289 TR2/3/3A Shifter knob jam nut Triumph 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
jfarris TR2/3/3A Castellated nut on the pinion Triumph 9
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
AN6-TX Hex Nut 2BA? Austin Healey 4
K TR2/3/3A The nut and the olive...no not a Mediterranean snack? Triumph 6
K TR2/3/3A The Steering Wheel Nut Triumph 20
