bighealeysource
Hey all,
My 1954 BN1 has not had the original fan blade on for some time
as the previous owner of 30+ years simply used an aux fan
if things got hot. Well, I have gone to put the fan on
and find that the nut that goes on the water pump shaft to
hold the pulley on is apparently thicker than standard.
By that it appears to be about 1/2 inch in thickness versus
I would assume 3/8 or so for a standard one. I have not been
able to find a replacement nut anywhere. If I attach the
fan to the pulley with the correct bolts the extra thickness
of the above nut means I have a small gap to overcome between
the fan blade base and the pulley. Could I use some small
stainless steel washers to close that gap and have the
fan blade tight up against the pulley ? It seems like a good
idea but my only concern would be vibration. Looks like it
would take about 3 washers per hole to make everything fit
flush. What do y'all think ?
Thanks,
Mike
Thanks,
Mike
--Mike
