R
RonMacPherson
Not gonna roller bearing it? Like the domestic builders are doing to all the latest v-8 engines....
Mr Rego said:It's not for lack of trying Ron, but this one is beyond what I'm will to spend or risk if the grind fails and I scatter an engine.
With all of the talk of cam issues these days, I just want one to last half as long as my original did. By then, I'll probably be to feeble to drive it anyhow. I could go sit in in it, in the garage and make vroom, vroom noises like I did when I was a kid.
RonMacPherson said:Sorry, I was talking about roller bearing the front, flat face bearing between the lockplate and the cam. Like you see in Jegs catalogues all the time.
To me it would appear to be a lot of extra machining, full circle lock plate, and cutting it for the right clearance between the cam. Just dunno if the effort would be worth the machining cost and time with the cam riding on steel. Now if it had bearings in the block..........?
