TR6 now what have I done? choke on rebuilt carbs....
cmacmillan
Rebuilt carbs back on the '75TR6...thought I put'em back as they came off....idles at about 1300 with the choke fully out and up to 3000 with the choke in. Shouldn't it be higher idle with the choke out, and lower with the choke in? Should I take them off and re-install?
TomMull
Most likely the choke is richening the mixture to the point where it slows the engine. The problem is likely in the linkage. I would disconnect the throttle linkage at the shafts by loosening the link between the two carbs and then pull the butterflies completely shut. You should be able to completely kill the engine by shutting them. If that works, re- tighten the connection and adjust the idle speed with the screw. Tom
poolboy
Yeah, check the tail end of the choke cable; it may be hanging up on the linkage.
cmacmillan
cmacmillan
Follow-up...choke cable seemed ok. Raised the pistons in the carbs (engine off) and the butterflies were closed. It won't fire unless I hit the carbs with some quick start (at which point it starts up like pro), which I'm guessing has to do with too much air pulling in. Anyhow, with it idling at 2500 rpm, I can kill the engine by fully blocking the air intake. I can get it down to 1200 rpm by partially covering. Someone mentioned spraying butane around in case there's a leak - seems like a recipe for an explosion, but maybe I'm too cautious.
Thoughts?
poolboy
Come on, do you really think someone would try to get you to blow yourself up ?
cmacmillan
cmacmillan
Hahahaha - maybe not....could I get something so wrong that I end up blowing myself up? Likely! I won't mention how many times I've shocked myself working on the coil.
mctriumph General TR They are never DONE!! Triumph 5
PAUL161 NASCAR, I'm done. Racing 11
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
S TR2/3/3A carpet kit and the interior done Triumph 8
J Shroud Painting ["Finally done with these"] Austin Healey 3
dougie Fresh Nasty Boy - Well Done Austin Healey 3
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
Rut What have I done? Spridgets 11
R Valve lash - Is this how it is done? Lotus 4
L Tastefully done, no? Austin Healey 16
simon1966 All the prep is done, time for real paint! Austin Healey 6
CLEAH What crazy things have you done with [to] your Healey? Austin Healey 21
D Paintwork done. Austin Healey 8
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
R Where did it go? A who-done-it mystery! Austin Healey 18
5 TR2/3/3A Macy's Garage restoration done and having fun Triumph 6
J MGB Project car done: idle variable MG 2
J MGB Project car done; front end clunk noise while braking MG 4
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
PAUL161 T-Series The TF Is Done! MG 15
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
J Alternator Conversion - Gutting the RB340 Regulator What must be done? Austin Healey 16
M General TR Restoration done, Picture time Triumph 33
PKPoole TR2/3/3A Done! Triumph 21
D Dash Recovering - Almost done Spridgets 32
J TR2/3/3A Kitty is done! and legal on the road this time. Triumph 7
60TR3A TR2/3/3A I Had a Portrait Done of My Car Triumph 13
WillR MGB Turn signal ground issue DONE. MG 0
tomshobby color sanding done and first stage buffing Spridgets 4
K TR2/3/3A Trunnion replacement done....Thanks to Forum Triumph 3
C Paint work is done! Austin Healey 15
Mickey Richaud MGB Nicely Done! MG 3
C Handsomely Done Jensen Healey! Other British Cars 6
drooartz MGB New interior panels are done! MG 5
thechileman TR4/4A My '64 TR4 is done! [basically]... Triumph 11
D Finally done cleaning!!! Spridgets 2
D Front tilt bonnet done Spridgets 8
D Front suspension and steering done - almost Spridgets 18
B Now What Have I Done? Spridgets 4
D Finally got something done... Spridgets 8
bighealeysource Trouble getting toe in done on BN2 Austin Healey 16
PatGalvin It's gettin' done, slowly... Triumph 72
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M TR2/3/3A TR3 paint is almost done Triumph 10
M Insulation Done [pics] Triumph 6
PAUL161 T-Series New house finally done! Dug TF out of the barn! MG 10
George Zeck Front Shock Upg Other & Upgs nearly done ....... Spridgets 18
G Got the 6 interior done Triumph 3
