jaybird
((Click on the link in my sig))
or
https://www.imagestation.com/album/pictures.html?id=2109094711
Most recent pictures are near the end of the 'album.'
((so much for dove grey looking like shiney primer!))
All body work is done, driver's door acquired and ready. Primer's on the outside of the car (paint in 8 days). Tranny (I know, I know) is cleaned up, engine was picked up from the machine shop today, header, block, crank, all pretty and nicely wrapped in plastic. (got to start building that thing right away or we're going to have to get oil all over it).
Not sure if the price is good or not from the machine shop. I really don't care at this point. Here's what he did (Chuck P&P'd it himself)
hot tank block
bore & hone block .040 over
install cam bearings
clean & polish crankshaft
balance short block
clean & check rods
install pistons
resurface flywheel
resurface exhaust manifold
valve sob - clean, check, grind valves and seats
assemble head with new valve seals
install intake and exhaust seats
resurface head
press bushings & hone to size
$700
I also have an alternator and it works and Emma runs (tested at 14.19)
Life is good.
or
hot tank block
balance short block
clean & check rods
install pistons
resurface flywheel
resurface head
$700
Life is good.
